having vtec problems
  • having vtec problems
    alrite so i got my jdm b16 in my hatch with a p28 with a type r chip
    the vtec kicks in sometimes
    oil is good
    changed the ecu
    check the plugs
    cleaned the solenoid
    what else can i check?
    i read on a forum that the tps can cause that?
    u have a knock sensor? any cels?
      yea n idk lol
        do u have a check engine light
        D and G auto member #5
          how long has it been doing this? since u had it? or it start after u had it???
            check the headlight fluid?
              Check the tps or Chang ur cluster dose r mph work on ur cluster??
                Who made the map.on the chip ?
                  idk i got the ecu like that but it was workin fine on my 4 dr
                  ima check the tps tommorrow an the cluster works
                  fag
                  it just started
                  yea
                    lololol
                      chek wat codes u got goin on dude... if u got a check engine lite it aint gonna werk..
                        ive always had the check engine light ever since i have the swap an it was workin fine
                          trust nigga... u gotta get rid of tha check engine light... vtec will never fully pop unless u get rid of the check engine.. it mite feel lik it sometimes... but mmmmmmm no...
                            Trust it did mad loud too it just stopped workin like a week ago..I've had it running for months
