just got 96 acura four door LS..i wanna make it LS VTEC. CAN anyone help me knoe what to get..give me a list plz..thank you
Help build my LS PLZZZ..
Originally posted by ct tibby View Postb16 head and sum jb weld pull the stock head off put the b16 one on jb weld the whole head gasket an then impact the head bolts on as tight as u can so when vtec hits it wont lift the head.
Man there are plenty of ls B20 vtec write-ups online look it upS3-R
Stage3-Racing
Originally posted by ct tibby View Postb16 head and sum jb weld pull the stock head off put the b16 one on jb weld the whole head gasket an then impact the head bolts on as tight as u can so when vtec hits it wont lift the head.mr.snuggles to you bitch
first you gotta get a vtec head. gsr wire harness unless you wanna hard wire the vtec solenoid, get a gsr or p28 ecu, get a ls/vtec kit, (sandwich plate, oil line, the plugs 150 ebay) get a head gasket and dowel pins. head bolts. thats pretty much it, and timing belt for the vtec head.~StayinFRESHSINCE1982~SPUNKY MONKEY CREW MEMBER #1203 CREW MEMBER #33
Originally posted by Mr Layy View Postfirst you gotta get a vtec head. gsr wire harness unless you wanna hard wire the vtec solenoid, get a gsr or p28 ecu, get a ls/vtec kit, (sandwich plate, oil line, the plugs 150 ebay) get a head gasket and dowel pins. head bolts. thats pretty much it, and timing belt for the vtec head.R.I.P Nick aka NHSwaps
