I want to delete my ABS dont know where to begin.. not to sure how it works
DELET ABS on DC
get the front brake lines from a 92-95 civic and proportion also from master to proportion valve. The back brake lines are the same take ur master cylinder to advance auto parts or autozone and ask for non-ABS master cylinder( your old cylinder will be ur core) and you will also need a integra NON-ABS brake booster the ABS booster the rod is too long and if you use the ABS booster with NON-ABS booster the brake fluid will not return to the master cylinder, meaning it will only pump fluid until the all four rotors will start braking by them self..... TRUST IT HAPPEN TO ME, NOT FUN AT ALL good luckbecuase its JDM!! It has to be better!
Originally posted by Ritoshi View Postget the front brake lines from a 92-95 civic and proportion also from master to proportion valve. The back brake lines are the same take ur master cylinder to advance auto parts or autozone and ask for non-ABS master cylinder( your old cylinder will be ur core) and you will also need a integra NON-ABS brake booster the ABS booster the rod is too long and if you use the ABS booster with NON-ABS booster the brake fluid will not return to the master cylinder, meaning it will only pump fluid until the all four rotors will start braking by them self..... TRUST IT HAPPEN TO ME, NOT FUN AT ALL good luck
the hardest part of it all was threading the damm lines on the proportion valve lol. All the lines and proportion valve i got it @ the junk yard for less than $40 the master cylinder was around $60 with the core, booster was $160 or less with core. Once done bleed all rotors and you good to gobecuase its JDM!! It has to be better!
Originally posted by Ritoshi View Postthe hardest part of it all was threading the damm lines on the proportion valve lol. All the lines and proportion valve i got it @ the junk yard for less than $40 the master cylinder was around $60 with the core, booster was $160 or less with core. Once done bleed all rotors and you good to go
