2000 gsr issue
  • 2000 gsr issue
    burns oil real fast also engine light comes onand won't let me pass 5gs on rpm gauge any suggestions
    nobody got a idea or anything wtf
    ALL MOTOR RSX
      Sell me the swap
      Originally posted by LS/Vtec
        sounds like you got a situation.
          If your burnin oil my guess would be bad rings. Due to it burning oil, your oil level goes down, lower and lower each time you run your car. Soon enough it'll get so low that your vtec oil pressure sensor will sense a low pressure of oil, not enough to engage vtec and will cause your car to begin red lining at 5k so you dnt cause any damage to your engine. Which will also cause a check engine light.
          That is my guess.
            Whats the mileage on the car?
            NO $$$ NO FINISH LINE!!!
              bingo alex
              My transmission's went 9's
              http://youtu.be/z2PHemIp_Tg
                That is my guess.
                x2 valve seals could be leaking as well. car smoking blueish smoke?
                  yea the actual oil burning could be many things. rings, valve seals, pcv valve. or it could be leaking lol.
                    happened to my b16 when i had it turned out to be a cracked piston
                    CT 8thgen civic
                    R18 crew member 828
                      You need new muffler bearings
                        x2. Could be that. If the bearing is bad. It will create blow by causing low compression and burning oil.
                          Ilike this lmfao
                          ALL MOTOR RSX
                            Lmao
                              Originally posted by RLA_EJ1 View Post
                              Lmao
                              lmao!!!!!!!!!!!!!!!!!!!!!
