MAYBE VALVE SEALS ARE WORN.. TO SHIT.. DO A COMPRESSION TEST.... SEE WHA YOU GOT ACROSS DA BOARD.. CHECK SPARK PLUGS SEE IF YOU GOT OIL BURNIN OFF OF THEM..............
THIS IS A GOOD IDEA.......BECAUSE A COMPRESSION TEST WILL TELL YOU WHERE THE OIL IS COMING FROM........YOU DEFINITELY SHOULDN'T DO A LEAKDOWN TEST..........
obviously he's going to have oil on the plugs if it's coming out the exhaust.
do a leakdown test on the car, check coolant bottle to see if it looks like a milkshake-same with dipstick.
