will pro1 cams work 4 me
  • will pro1 cams work 4 me
    I was wondering if the skunk2 pro1 cams will work with 1mm oversized valves on the intake and exhaust side and using arias 9-1 pistons what u think
    on wat type of motor and wat do u plan on doin it seems like boost
    eh9 jdm b16
    Pimpbays
      Im pretty sure they say to use em with stock sized valves. But i've seen people use 1mm over sized valves with no problems. Just check your valve to valve clearance.
        its in a 2.0 ls v i just cant afford to start the motor and everything fuck up so trying to find ou tthe most i can thank
          well wats wrong with it
          eh9 jdm b16
          Pimpbays
            I just want to make sure im not going to get valve to valve when i start for the first time
              I think that you should sell those cams and pick up some tuner2 I have seen too many heads with the rocker arms eaten up by the pro series. those cams are too agressive to run on a street car that actually have to drive and idle
              (860) and beyond
              #DavesTuning 8608050968
                im sorry but ima have to disagree...pro1s basically have the same profile as stage 2 tuners and i dail drove my lsvtec with pro2's back in 07 with no issues...i had supertech valvetrain and always stayed on top of my valve lashes.
                op, if your going to boost this motor then these cams are an excellent choice...they make great power on boosted applications...of course depending on turbo/manifold and other supporting mods
                Team T&W
                Winning is the only option
                  Basically is not the same, also he has 1mm oversized intale and exhaust valves. would you still recommend them now. How many rocker arms have you seen destroyed because of them.
                  (860) and beyond
                    Gromo was also given the same advice by someone close to me. By the way, did you tell the engine builder that you were going to go with Pro series cams?
                    (860) and beyond
                      Bump for dave!! Experience talks!! I miss u!! Unamped
                        lol I don't plan on gonig anywhere anytime soon. You know where to find me
                        (860) and beyond
                          Bump for unampedness help me sell my car and turbo parts please!!
                            they are basically the same...im not trying to play you but they are. The vtec lobes on the two are basically the same and the primaries are a TAD bit bigger on the pro1's. You have longer duration on the tuner 2's than you do on the pro1's.
                            tuner 2's intake: .489/275 exhaust: .469/270
                            pro1's intake: .496/264 exhaust: .469/264
                            Acura Integra - Skunk2 Stage 2 cams vs. Skunk2 Pro 1's: Pro's and Con's for my build Plz!! - Sup guys. First of all, I wanna thank everybody who responds to this for their input, it's very much appreciated. Now for my question: I was going to go with Skunk2's Pro Series Stage 1 cams, then the guy who's helping me with...
                            and if the motor is built right and the cams are properly degreed then why cant he run oversized valves? and I have seen ZERO rocker arms destroyed.
                            Team T&W
                              yea mike did the work on the motor he put it together everything hewrote on my papaer work that he checked all clearance valves everything but when people tell me it not going to work i dont want to turn it so dave what do u think i should do
