goin to b a hard prob to describe
  • goin to b a hard prob to describe
    Hopefully sumone will kno wat ima talkin about I am goin to try my best in describing my problem.... U kno when its cold outside n the alternator belt is loose The alternator belt makes that screeching sound that to get rid of the sound u hav to rev the gas?! Well its something like that but not as loud and the belt is tight and it only happens when I accelerate it may not even hav anythin to do wit the alternator but I can seem to figure it out n its sum wat of the same noise jus lower that's y I'm relating the 2 does anyone kno wat that culd b?!
    describing in proper english would help do you intentionally write like that ? but anyhow try tightening your belts cuz day loose.
      Sorry sir I will edit it later. Does anyone know how u know when its time to change your timing belt?
        some cars are every 60k..but just take the timing belt cover off see if there are teeth missing or cracked
        WILSON BUILT
          check pulleys n belts
            Do you have an aftermarket intake and filter? Because my cousins car used to make a slight "squeel" when he accelerated and it turned out to actually be his intake making the noise. He went and bought a better filter for the intake and it stopped.
              change the belt
              D and G auto member #5
                Yes sir I do wit another tab for a mini filter
                  check your flywheel
                  ~StayinFRESHSINCE1982~
                  SPUNKY MONKEY CREW MEMBER #1
                  203 CREW MEMBER #33
                    Is the belt new? It may be on too tight.
                      Originally posted by Mr Layy View Post
                      check your flywheel
                      My flyWHEEL? Can. U elaborate plz
                        my car use to legit whistle when accelerating from my intake lol.
                        VTEC is just way to much fun
                          it could be ur actual altenator my dad was doin tha same wen u start it it makes tha squeel than goes away than comes back wen u give it gas or load. we checked tha belts like 20 times and he just went to autozone and got a new one stopped makin tha noise
                          B SERIES INC....
                            thanks everyone for the help ima chack it out this weekend
                              damn my g u still need that shock ??
