help!!!!!!!!!
  • help!!!!!!!!!
    ok well i tryed over n over again to fix this issue but there is no luck for me.. i have a bseries swap in a ef n im having a starting issue.. ive replaced the starter 4 times n i checked all my fuses n all the grounds... the starter still will not spin... the piston on the starter pops out but doesnt turn the motor at all.. randomly the starter works wit remote start n someeetimes by hand but im all outta ideas. pls help..
      so it turns on wit the remote start??
        Sometimes not always.
          When I let the car run for a while it doesn't start back up but almost always starts the first time. Wit remote start
            who did tha wiring?? wat dizzy u using??
              and when u start it wit tha remote start.. is it like normal can you just put tha key in and go?? u tryna get it started tha normal way rite?? any problems b4 u did tha swap wit it..
                Everything else is good the car runs nice just a bitch to start. When I turn it o. Wit the remote starter I put the key in and drive off just everytime I turn the car off it acts up. Its been a problem for Bout a year. Change alot of starters grounds n Ext. Idk
                  are you sure the starter is turning? do you actually hear it turn over?
                  ~StayinFRESHSINCE1982~
                  SPUNKY MONKEY CREW MEMBER #1
                  203 CREW MEMBER #33
                    could be your ignition switch maybe. Or your alarm wiring. If you have a relay inbetween your starter wire for a starter kill maybe thats acting up.
                      The starter doesn't turn just pops out
                        It could be ur flywheel id u missing some teeth on the flywheel ita probably ur case it happen to me on my EF sedan
                        (203) Crew Member #15
                        R.I.P Nick . We love you homie
                          The flywheel was str8 when I looked at it. I will check it out again thansk
                            so what your sayng is... the starter pops up but doesnt turn?
                            203 CREW MEMBER #33
                              Yea that's what I'm sayin
