spun bearing question
  • spun bearing question
    I got a ls block with a spun bearing and was wondering what is the complete process to repair the block.Any info will help.Someone brake it down for me lol thanks guys
    Originally posted by LS/Vtec
    spun rod bearing? or main bearing? If it's a stock ls and you don't plan on building it. It'd be easier/cheapier to just get a new good block
      lol
        you got two options, 1) if the crank looks too scored send it to the machine shop $$$. 2) if its scored but rounded, use oversize bearings.
          Yeah it's a spun main bearing
            x2........
            usually rod bearings go...so with that being said I would do like ls/vtec said and get a new block. In most cases if a main bearing goes then the mains are scorn also...$$$$$$$$$$$$$$$$$$$$$$$
            just get another block
            Team T&W
            Winning is the only option
              Machine shop
              *S14 Kouki *
                Originally posted by JDM8o9 View Post
                Machine shop
                x2
                ~StayinFRESHSINCE1982~
                SPUNKY MONKEY CREW MEMBER #1
                203 CREW MEMBER #33
