oil in my radiator "!!
  • oil in my radiator "!!
    Yea I just change the oil,and waterpump and head gasket I turn on the car now my Radiator is getting oil in it wat could it be?
    warped head or head gasket not installed properly. How much oil? It could be from when you pulled the head off the block. Oil may have went into the coolant jackets.
      can't be the head cause i just got it out the machine shop and the head gasket was put on correct wat else could it be?
        Buuuuuuuuump
          is coolant mixing with the oil too? check the intake gasket
            Close its the head gasket
              you put it on upside down or backwards?
                WTF!!!!! ya dont listen to 1 word i EVER say kain...I told Brian its the head gasket!!!!!!!!! People RARELY use the headgasket that is supplied with the lsvtec kits....OEM OEM OEM!!!!
                Team T&W
                Winning is the only option
                  x24234534456346456
                  Team T&W
                    whats gay about the ones i always use. Is I use the ehad gasket to the block where im pretty sure golden eagles use the one to the head (so im told). But when you go to put the dowel pins into oem ones they never fit threw the hole and you have to bore the hole out some. Atleast I ran into that problem with the last 4 ls/vtecs i've done. So I dnt think it was a deffective gasket.
                      hahahahahah lol wat a noob
                        x3 for head gasket upside down
                          your right they use the ones to the head...your suppose to use the ones to the block. And you need a 9/16 drill bit to drill out the holes on the exhaust side to allow for the lsvtec dowels...its real easy tho.
                          I lost track of how many lsvtec's ive done lol. but each time i do it i treat it like its my first time because they have to be done the "right" way. thats why ppl cheap out on them or talk shit on the set up because they either fucked sumthing up for being cheap or they didnt know what they were doing
                          Team T&W
                            come on kain as soon as it did that u should have taken the head off
                            D and G auto member #5
                              ^^^it wasnt him it was one of our boys
                              Team T&W
