Any one use? or heard any good or bad about them. may be getting a stage 2 set for my ls vtec cause there a little more in the price range. and better then stock cams. and i was gonna replace the valesprings, retainers,and valves already, and i already have S2PS adjustable cam gears.
Brian Crower Cams?
see my original goal was to hit 250 on the motor. and it is seeming more more like it aint going to happen, but i still really want to. idk if my goal for 250 is just outa the picture. its gonna be a lsvtec, with 81.25mm CTR pistons on the ls rods. crank re ground down due to spun bearing, then rebalanced, and in the head, its gonna be like what i said, and the cams, idk. and im gonna be on a S100 dyno tune probly.
along with skunk pro2 intake mani, throttle body havnt decided what kind yet, intake and exhuast.Last edited by 95egB16A; 07-06-2010, 09:42 AM.VTEC is just way to much fun
Originally posted by 95egb16a View Postsee my original goal was to hit 250 on the motor. And it is seeming more more like it aint going to happen, but i still really want to. Idk if my goal for 250 is just outa the picture. Its gonna be a lsvtec, with 81.25mm ctr pistons on the ls rods. Crank re ground down due to spun bearing, then rebalanced, and in the head, its gonna be like what i said, and the cams, idk. And im gonna be on a s100 dyno tune probly.
Along with skunk pro2 intake mani, throttle body havnt decided what kind yet, intake and exhuast.WILSON BUILT
thats actually what i was thinking most recently. and i dont really wana change the fuel rail/injectors/fuel pump rite now. im really only worrying about internals, cause once i find a fucking job, shit gets brought to machine shop. and i need my eg running im sick of this stupid slob (aka saab 900s) and i was gonna go to dave for the tune.VTEC is just way to much fun
op, your not gon come close to 250(no offense). your gon need at least 2.0 liter, waaay better cams, some port work, victorx im, and at lest 440 injectors.
if you wan keep the 81mm bore then get yourself some 81.5mm pr3's (ctr pistons are garbage), arp rod bolts, get your head decked, cleaned, flat face valves, full valvetrain, edlebrock performer x im, 68mm tb, at least 370 injectors, and skunk2 PRO2 cams. the pro2's are proven time and time again to make power on 1.8 set ups.
a friend of mine in PA put down 226whp with basically the same set up as i just listed. he also had 3inch exh, cai with velocity stack, and rmf header.Team T&W
Winning is the only option
