so yeaa i got b sereis vtec big problem?
  • so yeaa i got b sereis vtec big problem?
    My car stays idleling at 3rpms it started this morning after a hour drive let me
    know wut it can be plz!
    BUMP IF VIEW?
    Vac leak bad tps
      could be a lot of things. does it idle solid at 3k or up n down?
        sounds like problem i had... car wont go past 3k rpms.. need new distributor and or main relay
          BUMP IF VIEW?
          Well it can be a few different things. what town are you in maybe there is someone local to you from the site that can help you.. but it really sounds like something simple..
          860 member #18
          puerto roc #1
          Cosa nostra
          ASAPRadio.net
            Its like this I drove for like an hour then I got to tha place when I made my first stop it started idling up and down to 1 to 25 rpm then I parked it to cool down then when I go to turn it on it stays idleing at 3 rpm let me know I wanna fix it but ima see ima go outside and check everything!
