ls/v wont start need help asap
  • ls/v wont start need help asap
    i put my ls/v in today 94 block 99 type r head, im getting spark im getting fuel but it still won't start, dizzy and everythign is obd2 and im using an obd2 harness as well, motor is in a 92 bubble
    good luck idk anything about this lol .
      Did you check and make sure you connected the ground wires on the tranny and valve cover?
        ya thats the first thing i checked
          when you turn the key to the on postition is your fuel pump kicking in
            yes it is
              check the ground thats on the thermostat housing that happen to me gl
              rip nick nhswaps kking of ct
                thats good too lol.....bout to just pull it out and put my ls back in, don't have to for the bs
                  just for the hell of it pop another ecu in there... and what kind of computer is in there now?
                    i got it, took dizzy out and turned 180 degrees (thought they only went in one way)...but i got a p28 and its in need of a tune bad, no power at all until like 2800 but after that very nice power
                      good, you got it! hows it running? if you need a VERY GOOD shoot me a text and ill recommend some one for you!
                      Team T&W
                      Winning is the only option
                        if your getting spark and fuel, everything electrical is ok grounds etc.. check timing.
                        nvm you got it running lol.
                          If you dont have adjustable cam gears youll never get it tuned right
                            Try new ecu its probably burnt!
