even if the timing was off it should still start .. my buddy set his timing wrong and valves were smacking the pistons lmao ... and it still started... im just not getting spark ... im gonna ohm out some more wires and stuff.. and as singleslam said its prolly the most rediculous little thing im over looking... soo im doing new plugs and wires today too lol
timing is mint.... timing wouldnt not give me spark ... unless its really that crank position sensor not being used... the ckf trick isnt working its def right i did a continuity check this morning on everything to make sure it was good .. im gonna try an obd2a-obd1 conversion harness with an obd1 p72 and see what happens...
yeah bro...mess with the grounds if u say that uve double checked what uve checked because half of the time it passes thru ur mind and it could b the smallest thing.
Its ALWAYS something stupid bro... Just go over your ignition system and make sure everything is up to spec. man.
Dist. cap, rotor, ignitor, etc. =/
Not really sure what the problem could be but if there's one thing I've learned about working on any car is that it's always something stupid xD
