my 96 integra GSR won't go into gear...i changed my clutch master and slave cylinder in the last 6 months and it drove fine, clutch gripped well then randomly a few weeks ago my car would shake a little in first gear and i had to pump the clutch a bit for it to get into gear. I have since bled the clutch lines 5x..some air came out, it went into gear with no problem, clutch gripped fine. Then 5mins later my problem returned and my car wouldn't go into gear. it has the oem clutch still with 120,xxx but it was never really beat on and it grabbed fine a week before my problem occurred. Also i have noticed my clutch fluid go down a little bit, but i checked for leaks behind the master cylinder and on the floor, there is none so im kinda lost as to what my problem could be, i refilled the clutch fluid too btw before bleeding.
Car won't go into gear!!
Originally posted by LS/Vtec View PostHave someone press your clutch pedal down well you watch your slave cylinder to see if it's working. Can you put it into gear well th car is off?WTB Work, Mugen, or Volk wheels
Originally posted by LS/Vtec View Postprolly a shitty slave cylinder if it goes in fine when the car is off.WTB Work, Mugen, or Volk wheels
that could be your problem. If your just gonna buy a new one and see if that fixes it i'd just go to Autozone cuz they are only like $20 brand new. That way if it's not that you didn't waste a lot of money. Hopefully it's just a bad slave cyliner n leaking up fron at the slave cylinder so it's a cheap easy fix.Money ain't a thing! Crew Member #1
Originally posted by jrsc_b18c1_12psi View PostSounds like you broke something in the disc meaning your gonna need a new clutch same thing has happened to me twice using ebay clutches spring from disc broke off and wedged into the pressure plate making it so it Wouldnt releaseMoney ain't a thing! Crew Member #1
Originally posted by jrsc_b18c1_12psi View PostSounds like you broke something in the disc meaning your gonna need a new clutch same thing has happened to me twice using ebay clutches spring from disc broke off and wedged into the pressure plate making it so it Wouldnt releaseWTB Work, Mugen, or Volk wheels
