Check Engine Code 4 Help!!!!
  • Check Engine Code 4 Help!!!!
    Delete!!!!!!!!!
    um ok...
    code 4 crank position sensor if its obd-0/1 then its the dizzy
    if its obd-2 reaplce the crank sensor on the side of the block
    someone correct me if im wrong
      Originally posted by sikciv666 View Post
      um ok...
      x2.....sounds good to me...
      337_runner
      HIGH OUTPUT CREW #1
        It's a full b18c5 in a 91 hatch, but has ecu jumper harness so it runs obd1 ECU, OBD1 Distributor and OBD1 Injectors. Lemme kno asap. Thanks!!!!
          i know what the problem is... you should take out the motor and give it to me :D lol
          Its only A Single Cam
          I my EF
          93 Nissan Sentra 4Dr Xe- Gone
          91 Civic Hatchback- sold :(
          95 Nissan 200sx SE 2Dr- Sold
          08 Subaru Legacy Sedan- Love It banna
            Ok I'll have it out at the latest 5pm tomorrow. Can you pick it up or do I need to drop it off. let me know. Thanks. lol
              sounds like a plan.. ur bringin it in the hatch when you give me the motor at the same time... then will push your shell aback to the crib
              I my EF
                Iight no doubt lemme kno wat time is good for you.
