wire harness prob
  • wire harness prob
    wat kind of wire harnees to use wen throwing a b18b1 in a 1996 ek
    96 98 EX obd2a
    " Mr. Tough Guy "
      the wire harness from the ek that your using since its a 1 peice design
        use thew one that came with you car should fit on the motor
          idk thats y eg's the way to go
            The stock one should be fine since your not running any vtec lines or anything.
            97 Boosted Hatch my toy
              x2
              J-ROC TUNING
                you can use your stock wiring harness. i just put same engine in my ek.
                  do note if its a DX model you have to make a few changes at the ECU point due to the old y7 motor and cut and extend a few wires but if its a EX you can disregard what I said.
                    Originally posted by crito07 View Post
                    96 98 EX obd2a
                    save the headache
                    " Mr. Tough Guy "
                      save the headache
                      True that but them harnesses are like GOLD for the ek's lol due to the one piece design he prob got his swap running by now though he hasn't even replied
                        i know.. but i aint have that problem since my EK is a EX lol.. thats exactly why i got the EX
                        " Mr. Tough Guy "
                          yeah I hear that man but to each its own i'll wire up what ever lol hell soon I wanna do a K swap and learn the wiring for that save some money lol
                            if its a dx u will need to re pin the idle air control valve and if u run the obd2 ls ecu u will need to change the plug on the harness for the crank pos sensor to the b series one, i believe the back up sensor plug is the same, use it from a spare harness
                            My honda better than yours :D
                              only the re pin on the dx harness for the idle air control valve, everything else for the other harnesses
