ls vtec questions
  • ls vtec questions
    so i got the ls block ALLL taken apart crank out everything. and the second rod counting number one being the flywheel side, had a spun bearing and it chewed up the crank a little where the bearing sat obviously. so my question is i bring it to a machine shop to get cleaned up and ground down, all of them (the crank) and i need to know what would i need to get in order to compensate for the grinding? can you just get thicker bearings? do i have to get all new rods? or what. also have a b16a crank thats fine. but putting that in the ls block would be no difference correct? or if i use the b16 crank with ls rods and b16 pistons, would i be achieving anything closer to a ls vtec (basicly wana know if ill keep some tourqe from the b18) or will it be pretty much exactly the same as the b16?
    VTEC is just way to much fun
    so iv been doing some research on the P30 ecu and i have no speed limit, iv gone above 120 before, my vtec kicks in about 5,800 and redline is like about 8,200 or 8,300 is it USDM or JDM?
