so im putting an 96 b18b into my 2000 civic ex. it has the stock d16. its my first swap and all i have left to get are engine mounts. but when i go to hasport the mounts for my car say they fit alll b and d series engines. so can i use some of my mounts or do i need all si b16 mounts. any info willl be helpful. thanks
ls into an ek
bump.. u just need the back bracket to b a b-series.. but i am sure u could use ur d series mounts.. ma boy jst did one$$49 Cellphone that pays you $$$ !!
www.solavei.com/lopez2333
like the guy above me said. They are the same the only differ is the back t bracket. Also you need a differ drivers side mount bracket that bolts to the block. Normally new motors have the 3 bolt design one. You need a 2 post design one. I think maybe out of a DA integra.Money ain't a thing! Crew Member #1
Originally posted by PhrequenC View Postyour going to need the drivers side engine mount. with 2 bolts from your dseries. the stock b series one wouldn't bolt to the engine mount.you'll have to take the timing cover off to change it out.Money ain't a thing! Crew Member #1
ls into an ek
My apologies about the "Import" command ... it was soooo long ago that i did it ... i went back and found the answer for you ...
Navigate to the MP3 in the Finder, then drag & drop into your song.
Should convert automatically.
Jack
______________________________________________
instant loan | payday loans
