ls swap
  • ls swap
    got a 99 ls want to swap it into my 96 ek got da jumper harness do mounts have too change
    yea you need 99-00 si mounts and brackets
      tranny mount and rear brackrt
        yup and you got to use the stock harness from the civic with a jumper which you got and you can use the single cam drivers mount but i wouldn't you need the rear t bracket and tranny mount
        One Tire Fire !!!!!!!
          x2
          D and G auto member #5
            No it's the driverside mount you need as well as the t bracket off of a 99-00 si. Damn you guys garbage!
            ~StayinFRESHSINCE1982~
            SPUNKY MONKEY CREW MEMBER #1
            203 CREW MEMBER #33
              you can use your stock driverside mount you just need the bracket that bolts under the timing cover off a d.a ls.. rear bracket off an si. power steering line off the ls if you want pws. you also need to cut the flange off your cat and spin it a little then weld it. i just did the same swap pm me if you have any questions
