so in the pouring rain the other nite my relay decided to fill up with water nd start shorting/ melting the wires coming out of it ... no biggie there i started swapping harnesses to cover everything that melted .. now i have no spark i dried out relay it drove to where this all happened over nite . and can't get the check engine light to cycle ne ideas other than a relay because i jumpeds the whole thing till i canget a new one and i got nothin
melted harness swapped car has no spark
Originally posted by NHSwaps13203 View Postcheck yel/blk and blk/yel wires at the relay for power with the ignition on.
then check the black for ground.
then get back to me.
idk if i mentioned the check engine doesn't cycle at all and i've been driving with the fuel pump jumped at the back of relay for a while on the switched wire then one day that died so i jus plugged / unplugged from constant when driving i'ma try to go straight from relay to ecu a25 nd b1 see wut that does for me soon ima get the car towed to my parents were i can rip the fucker down to nuthin if needed
