block guard
  • block guard
    does the block guard position really matter, like if its at the top of the block or if its down an inch, i heard of overheating issues depending on where it is
    makes heat spots no matter were it is ill never use one again
    My transmission's went 9's
    http://youtu.be/z2PHemIp_Tg
      Never used one myself. But everyone I know who has said bad things and said never again will they use one. But take the guy aboves me advice because he knows from personal experience.
        my shits bored 20 over and i have a blockguard havent ran it yet still building my ls/v, do u guys recommend removing it and if so what should i do to make sure my sleeves dont get fucked
          Just make sure that the machine shop thats doing it are expert on it and you should not have any problem
            20 over boosting? or n/a?
              N/A for now
                no need for a guard all motor man better off without it i know i looks cool lol and seems like a good idea theres no need for it.
                  ok good to know, a machine shop put the thing in how the hell do i get it out lol
                    just make sure the one you buy is the least obstructive, water flows through there, so you don't want to block anything.
                      mines never overheated or had hot spots.....but i might remove it any ideas how with out going to a machine shop
                        only block guard known to work is g.e there cut out lets colant flow properly if ur planning on going turbo keep it is a extra ssecurity. and removing it haha think again it sucks i done it in the past and it berks up the block's surface which sucks. another thing the block guard has to be 1/8 below the top of the deck for proper colant flow not 1inch down! going further down can cause ur piston to get off balance and create a strees zone regardless u'l get a slight hot spot but is better off further on the top. and if ur machine shop installed it correct they should have welded 4 corners of the block guard to the block or aleast put "red" lock tight on all the meeting surfaces. iv used lots of this on numerous motors never any problems,,,,, i never had a stock sleeve crack or fail and iv pushed them very far a while back complete stock bottom end b18 block 25psi on a 5th gear pull thats major load it burnt the piston but block and rods were great i did this alot to see when she'l finally give held 3 months. no worrys on the horror stories ppl tell you just dont make the same mistake they did and buy a ebay junk get GOLDEN EAGLE. gl
                          mine isnt golden eagle, any suggestios so my heat doesnt spike? drilling holes maybe lol?
                            if is close to the top of the sleeve and is not welded remove it. take a flat head and go around a bit at a time so it slides up. dont berk the deck if so resurface it if is to far down call it a day and leave it alone just keep a good eye on your temp get any air bubbles out of your colant lines slap a new thermastat........ and wish for the best what brand u buy? golden eagle has double cut outs and 1/8inch holes which flows colant good.
                              i don't get it.. haven't you starter smashing that shit yet?? if i was trying to remove a bolt i wound be making a threat about it, i would be getting my impact gun, wd40 and all source of shit. lol
                              you are telling me there ain't a single spot where you can fit something to take it out, and you been here 4 days waiting for an answer.. lol damn dude thats crazy.
                              ight listen, i'll put your out of misery. the block guard is aluminum right, go to a welding shop and weld 2 little hooks on each end to take to take it out, they going to charge you like 10-15 bucks, and don't call your boy with the wire fed welder, that shit ain't going to work you need a TIG welder with A/C wave.
