First off I'm more of a k series guy but after looking into it more I decided to do a b series build. So my question is i have an ls now if i do a gsr head do i need a new intake or with the intake fit both the ls and gsr? also what about b16 does that change anything either? thanks!
Easy ? intake help!
if your talking about using a stock gsr mani you'll prolly need a gsr intake cuz the mani causes the throttle body to sit lower. But you can pull it off with the original intake. But as for mani's like mantyme said lsw/gsr are differ. B16/Itr are the same, LS/b20 are the same and gsr is on it's own.Money ain't a thing! Crew Member #1
Originally posted by LS/Vtec View Postif your talking about using a stock gsr mani you'll prolly need a gsr intake cuz the mani causes the throttle body to sit lower. But you can pull it off with the original intake. But as for mani's like mantyme said lsw/gsr are differ. B16/Itr are the same, LS/b20 are the same and gsr is on it's own.
