just want to know what type or cams somebody would put in to some how improve performace over the stock cams in a type-r. any help would be appriciated thanks
cams...
i wouldnt put the spec4's in with stock anything thats asking to break. I have spec 3 buddy clubs and i would even use those on a stock valve train. Possibly the skunk 2 stage2's if your not beating the shit out of it, the bigger the lobe on the cam the more strain and stretch on your STOCK valvetrain. ill buy the itr cams off u if u deside on any cams pm anytime man.My transmission's went 9's
http://youtu.be/z2PHemIp_Tg
x2 cept still rockin oem timing belt with 3hund plus wheel i would say since your already half there u may as well change the tbelt g/lMy transmission's went 9's
if you want to keep your motor stock, just got with the skunk2 tuner series, even block Bs. all the other ones will require you to bump your C/R cuz your motor is going to bleed out a lot of compression.100 Pennies make a Dollar, The same applies for HP
