So i have 99 civic lx and i purchased a b16 swap off a 97 hatch,now my question is....i got the engine harness that was on the car/motor,will this harness plug and play to my lx and if so what else would i need to do to the harness,it also came with a obd2 to obd1 jumper harness and ecu,any help would be much appreciated
99 civic lx b16a2 swap
Originally posted by civic2437 View PostSo i have 99 civic lx and i purchased a b16 swap off a 97 hatch,now my question is....i got the engine harness that was on the car/motor,will this harness plug and play to my lx and if so what else would i need to do to the harness,it also came with a obd2 to obd1 jumper harness and ecu,any help would be much appreciated
You can mod the 99 lx harness you have to work. Or get a 99-00 si harness for plug and play.
If you plan to run a obd1 ecu then you will also need a new jumper, but then you will NOT pass emissions.
Best to get the car running obd2 then worry about obd1
Also if you bring me your lx harness i can mod it to work 100% No cel's
96-98 are the same obd2a
99-00 are the same obd2b13203I DO REMOTE STARTS!
damn mad $ for a harness. Just get an SI harness so it's plug n play. Unless you know wiring then mod it, It's really not hard to do. Like nhswaps said get the car running then go to obd1. Or pay the $ and have him do it for you.Money ain't a thing! Crew Member #1
