when i drive for a while it starts heatin up... i turn tha heater off n it goes down normal.. but than wen its good temperature outside it doesnt ova heat... whats goin on??
heating problem
do you have enough coolant?? not being a dick; but sometimes you fill the radiator and there still bubbles trapped inside, you should warm the car up and keep poring water into it till you have no more bubbles coming out.
is our radiator cap milky?? cuz your head gasket can be going bad.100 Pennies make a Dollar, The same applies for HP
