b18c with b18b crank?
  • b18c with b18b crank?
    b18c with b18b crank? would like more info on this crank swap i know the stroke is increased to 89mm from a factory 87.20mm. Can i just bolt it on my b18c as if it was the original crank or do i have to send it to machine shop?
    Anyone done this b4 lmk.
    Follow me @bolacan413
    Follow the build @k_insight
    You have to run LS rods as well. Stock or aftermarket but you gotta make sure they are for a LS application.
      now after all that is said and done can i just bolt up the crank? ill have to mang the rods to fit gsr bearing right?
        also oil squirters have to be removed or bent to clear the crank.id say get forged internals ditch the squirtes and have a someone reputable do the work
        Midori green is so last year :)
          yea after all that i think ill just stay with my gsr crank
            you can make some impressive #s on the set up
              I wish i could see some #s I have a friend doing a GSR block like this. Does anyone have an idea how much WHP this setup could make?
                there's a thread on h-t about it..i think I saw someone put down about 215 or 220 is...81mm bore. I have to find it but its in there allmotor forum. it wa s compared to a lsv without the doing the conversion kit and still retaining the block girdle
                  this is EXACTLY the same as an LS/V, but you don't have to run all them oil lines and relocate dwell pins and shit.. all the rotation assembly is LS, so you need LS bearings, all Main bearings are the same. I go with B16 rod bearings if using OEM, if you are using aftermarket rod bearings it don't matter.. LS and B16 are both 19mm
                    Originally posted by panch View Post
                    this is EXACTLY the same as an LS/V, but you don't have to run all them oil lines and relocate dwell pins and shit.. all the rotation assembly is LS, so you need LS bearings, all Main bolts are the same. I go with B16 rod bearings if using OEM, if you are using aftermarket rod bearings it don't matter.. LS and B16 are both 19mm
                    yea i know ls and b16 rod bearings are the same... i need to know if i can mang the ls rods to fit gsr bearings cus gsr's hold more rpm's. and what can i do about the internals and oil squirter issue?
                      GSRs are 17.5mm wide, thats 2mm less than the ones meant to fit that rod.. you could get your machine shop to do it, just ask them if they done it cuz they be messing up on that, or you could just get ACL bearings they are only 30Something at E.S.T motorsports. Too much trouble to replace a bi-metal(b16) for a tri-metal(gsr). i would understand if there wasn't that many parts for these engines, but we got tons and cheap, just go ACL
                        you have to buy a block off kit or have them bent but trust me the squirters get in the way.....
                        good looks Panch, any other info would be greatly appreciated
                          goldent eagle sells a oil squirter plug kit and you sould still use aftermarket rods are at the least apr rod bolts. that is the whole prob with the LS/vtec set up the rod bolts cant handle the stress of the rpms. it wont make it any different in a vtec block still will strech and blow.
                            thanks
                              good looks Frank! when i went to assemble i had a crank somebody sold me and unfortunitly it wasn't LS, now i have the right crank and need another linebore after i mocked it up I know about the block off kit besides this list what else do i need patience is wearing LOL
                              -LS Eagle rods
                              -ARP hardware
                              -LS ACL rod and main bearings
                              -JE pistons (secret compression LOL)
                              -LS Crank ( the rite 1)
                              ...... lmk ct
