I have a b16 cable tranny with a ls cable starter. When inturn the key the gear on the starter comes out but doesn't turn the flywheel. When I hit the starter it turns. People say it's the starter. I replaced it twice. Works for a lil n does the same thing. I even took off the starter n had it tested at Autozone n it worked. Idk what it is pls help
Starter question pls help
Originally posted by BptzIllest186 View PostI have a b16 cable tranny with a ls cable starter. When inturn the key the gear on the starter comes out but doesn't turn the flywheel. When I hit the starter it turns. People say it's the starter. I replaced it twice. Works for a lil n does the same thing. I even took off the starter n had it tested at Autozone n it worked. Idk what it is pls help
my fault jroc, forgot he said cable.
yeah man i know my b16a2 starter is the same as ls typer and gsr
and i know 90-93 ls and gsr starters are the same so i wouldnt see why b16 wouldnt be the same but it could be. unfortunatly im only an acura parts specialist so i dont have a parts catalog for honda. but im waiting on my boy from honda to email me back with a part number for you cuz if its the same ill take one off the shelf and try that see if it fixes and if it does well work something out.
Originally posted by Jroc860 View Postok so where ever u get that info from u can get info on how to fix it G/L wit that
inbetween any b starter is that one has a long snout one has a short, only
time they wont be interchangeable is on a h2b. wrd.13203I DO REMOTE STARTS!
Originally posted by BptzIllest186 View PostI was told bseries is bseries. So I got a cable starter for a cable tranny. The starter worked for about 3wks then it gets stuck as if it's not strong enough to turn but when I hit the starter it starts up perfect13203I DO REMOTE STARTS!
