cold start up.
  • cold start up.
    Im assuming like any car honda computers have a open and closed loop, when i start my car in the morning it idles at 750 800 while its suppose to be over 1000 and slowly work its way down to 750 800 when its warm. Why is it just skipping over the warm up idle? Thoughts?
    My transmission's went 9's
    http://youtu.be/z2PHemIp_Tg
    My guess would be the valve(FITV) on the bottom of the throttle body where the 2 coolant lines go to?
      b16 man not one there. thanks for input though
        Damn that's my only guess. If you have another ecu try that? Because my teg was having the same problem and I swapped ecu's and it was normal.
          Cuz u broke something doing the swap
            lol thats impossible im perfect pizzagirl ask gaz if hes got an idea.
              Bad coolant temp sensor?
