harness problem
  • harness problem
    i was put in back together an integra 98 so i pick the car in the bones no harness no nothing when i mean nothing its nothing inside the car so i decide to take all the parts from my other integra but tha one was obd1 94 and the one the i bought was 98 so i use everything from the other one but when i star plug in the main harness under the dash board its some plugs left out they r brown in color like 3 or four and the car turns on and everything.... but the wiper stay on all the time, the sunroof open with the key on off and when u put the key on start it dont open or close,no light on the cluster so i think i connect some plugs wrong ............do some one in here have or know the wiring diagram for the main harness .....i no everybody say its just plug and play but its easy to say if some one can help me on this ill apreciated thanks in advance
    Nah sometimes its really not plug and play. 94-97 on some parts of wiring are different.
    You might have to do some customizing in wires, i had to customize my wires for my doors. I have 98 doors on my 94.
    Double check everything again just to make sure.
    Save money on your electric bill - Make money helping others save money on their electric bill!
    Contact me for details!
      i will recheck but im waiting for my boy to take the dash out to see whats wrong on my car
        94-97 integra obd1 wires are different then 98-01 integra's obd2 . you gonna have to rewire them or get a obd2 harness. i might still have the interior harness if u want it ill check tommorrow if the weather is nice. pm me for more info
        R.I.P Nick aka NHSwaps
          K I let u no after I check my boys car
            But why if I use everything fron the other car I use stering colum, fuelpump,fusebox,all the relays well i bought the car just in the frame cause it was nothing on I change where u put the key all that stuff but don no Im going to wait for my boy to take the dash board so I check what's wrong on my car he's car it's obd1 too
              well if you are using all 95 stuff on a 98 then it has to work, just use everything, floor harness, fuse box and dash harness.
              then have a great time trying to get that car registered, without the obd2 scan plug in the car.
              I DO REMOTE STARTS!
                So what u think I can do then ???? Can I rewire the scan plug or not
                  make ur life easier and get a obd2 harness.one of my boys might still have an obd2 harness.pm me if u need it
                  Midori green is so last year :)
                    yo
                    but if i use the obd2 main harness i can use everything inside the car its obd1 so it will work or i have to change everything to 0bd2 like fuel pump,fusebox,the system for the heater,the switch for the keys and all that or no
                      damn good luck
                      D and G auto member #5
                        Use the obd2 harness and convert it with jumper harness for obd1 and sellme ur obd1 harness
                        Integranation founder
                          o
                          let me see first what part i need to change inside the car to use obd2 main harness cause im trying to find on the internet but no luck and then i dont want to spend a lot of money buying stuff to put it again obd2 cause i got everything obd1 on the car allready
                            if u use a obd2 harness with the jumper harnes to make it go from obd2 to obd1 everything shud still work and u will still have the plug for emisions.
                              so that mean the fuse box,the relays ,fuel pump ,switch key ,blower heater ,they r the same plugs from obd2 to obd1 they r the same????the only parts the it s different its the plugs for the ecu and the plug for the scanner?????
