HELP PLEASE..........engine harness
  • HELP PLEASE..........engine harness
    i have a d16 single cam v tec engine harness. will the d16 harness work on a B18-A1 ls motor. the single cam is a obd1 and iam 99% sure the LS is too.
    please some one help me, and let me know before i drop the ls into my car..
    860-230-6608[/B]
    EM1-860-CTmember..1...
    J-SWAPS ....860-457-8335
    it will work fine just you will have the extra clip that will be for the vtec solenoid and you need to run the ls computer and it will be fine
      i have a stock P28 that will work
        no you need p75 computer cause the fuel scale is different on each computer and the p28 will look for vtec and throw a code
          even if i have a adjustable fuel reg on it .... worste case i can at least start the car with the p28?
            YEA U CAN RUN THE CAR ON THE P28. bUT IT WONT RUN CORRECTLEY. hIT ME UP IF YOU NEED A LS ECU
              yea it will start up and run just throw a cell for no vtec and it will just run better and be better on gas with the p75
                o ok thanks guys i was really thinking i was screwed. but also how you sell me the p75 for ? i got a B16 engine harness also
                  they go for pretty cheap and wont be too expensive
                    o alright thanks alot guys you saved my butt big time
