jdm b16a cam seal leak
  • jdm b16a cam seal leak
    Hey ct, I had oil all over my block so I checked it n it looked like it was coming from the vtec solenoid, so I changed the gasket n it stoped leaking bad, soo now I was looking at the cam seal in front of the distributor, n it has the tinyest leak, sooo my question is if I put a little silicone will it stop??????????
    they were selling that si for VERY cheap for a 2000 civic si. if i were you to be safe take that to a shop like high output in prospect and have him check that thing inside out.. compresion, leaks ect. ect.
      Na its good I did compression tests I checked spark plugs, it has an exhaust leak but that's it
        Thanx ct, I fixed the leak!!!!!!
          dude just buy a new cam seal
          95 civic ex - 13 to 1 compression 1.6 single jingle
            i have a golden eagle triple ring cam seal brand new lmk
