jdm gsr
  • jdm gsr
    put a jdm gsr in my boys ek used a gsr throttle cable but there still seems to have to much play and the treads are all the way out on the cable anyone run into this problem before .... and i know u cant use a type r with the reverse gsr gay throttle body. input?
    My transmission's went 9's
    http://youtu.be/z2PHemIp_Tg
    use a typeR cable or 00 si one. and tell him to throw out the stupid stock manifold and get a aftermarket one.
      its got a blox on it i threw the gsr in the garbage lol soooooo... the blox has a gsr throtte on it with a gsr cable u think its streched and u cant use a type r with the reverse gsr throttle penis face!
        same problem with my girls jdm gsr in a hatch... the type r cable wont work i think its too short,, what i did was use 2 sockets and made a spacer so it got rid of the slack.. its hard to explain.
          why are you runnin a backwards TB on a blox manifold. put a reg one on it and a red cable with bracket.
            u got one? ..... y am i not just calling u lol!!!
              x2 would be easier just swapping tb's.
              but..
              scroll dow to throttle cable. the said they swapped the "bell-crank" i guess is what it's called. But def easier to do the tb.
                damn alex where was that when i needed it!
                  nah u needed a map sensor n tps diagram lol
                    it would be easier if i actually had another tb to switch but im not givin him my itr lol
                      yea lol. make it as good as u can so he just has some slack until he can find another tb.
                        just get the right size wipers from auto zone highly recomend ur problem wud go away
