B16A2 troubles
  • B16A2 troubles
    I put a b16a2 into my ej1. I was told that the ex harness would work fine all I had to do was convert the plugs for the dizzy, I could even use the p28. I'm guessing that isn't it because the car won't start. It'll spin alllll day long but won't fire. I compression tested it, came out good, I checked spark, (not sure if anyone is familiar with the tool but the tool lit up, not real bright, but lit up) and same with the injectors. I'm lost, anyone have any ideas or anything? Thanks
    ground wires
      I have all the ground wires (brand new oem) brand new battery cables, brand new starter, brand new battery, even tried to jump it.
        u wired tha dizzy??? dats prolly wats wrong not tha right dizzy....happened wit me... drove like shit cus i had tha dizzy wrong... culd just get a obd1 gsr dizzy it will werk... same shit
          yeah that's the only thing I can think of and I don't hang out with too many Honda people so I can't really verbally work my way through it with someone. I have the ob2 B16A2 dizzy which is the same as ob2 gsr. So I can still use the eg ex harness with an obd1 gsr dizzy?
            and yes I did the wiring, and I get power past the dizzy, just wont start, turns and turns and turns, never fires
              just put tha plugs back... n buy a obd1 gsr dizzy from autozone or order a obd1 b16 dizzy online
                will try that, really appreciate it dood.
                  check the ground wire on the thermostat housing... people usually overlook it
                    This is vary true! Without that ground she wont start.
                      ground is there.
                      anyone have a obd1 gsr dizzy?
                        x2 happen to me
                        B SERIES INC....
                          u can use a ls one just have too cut one of tha arms to make it fit its cheaper and work just as good
                          B SERIES INC....
                            main relay
                              is it timed up ? is your firing order correct?
