OK so today i went to start up the hatch and it wont start...i popped started it and nothing happened....the secound time i did it...it started for like 1 secound then it cut off....ever since then it has'nt done it.....i spoke to singleslam and he said it could be mt timing...im gonna check that out 2marrow.....is there any other thing that it can be?
damn!!
i couldnt' think pop starting it would of been a good idea to begin w/ if it didn't start it was for a reason i wouldn't think timing if it ran last time u drove it ... i'd b thinkin dizzy or gas got water in it may b loose wire/grounds ... THE BAD IDEA ABOUT POP STARTING IS WHEN IT DONT' RUN UR PUSHIN IT BACK lmao good luck dude
ok it seems to me there are wayyyy to many online mechnics. First off all you said it ran and stat so water in gas i dont think so. Timing i dont think so unless your belt snapped. DIZZY IS A BIG POSIBILITY. IVE SEEN NEW ONES RUN ONE CYCLE AND GO BAD. ITS A HONDA MAN. Pull a spark plug wire see if there is any spark no spark check ecu fuse. If the ecu fuse is good go possiablity dizzys bad.My turbo is louder then yours!!!
