is anyone running this setup wat u guys think bout it im new to building motors but i might pick up a b17 block wats the best head to run on this block
b17 block with a b16 head????
yo teggy i txt u did u geta fone yet? but yeah we can talk bout sum shit lik wtf ami gettin ma steelie lol heard u got sum blades but as for the block idk wat ima do with it ima go check it out sat to c if im actualy gona get it
Integranation founder
Yeah your best bet is to to go ls bottom end. your power levels will be achieved with minimal cash meaning alot less money has to be put into it to make better power goals then going b17 bottom with b16 head.. g/l bro i hope everything works out for you.860 member #18
puerto roc #1
Cosa nostra
ASAPRadio.net
Originally posted by single slam 12 View PostYeah your best bet is to to go ls bottom end. your power levels will be achieved with minimal cash meaning alot less money has to be put into it to make better power goals then going b17 bottom with b16 head.. g/l bro i hope everything works out for you.
i would say lsvtec as well,,being both affordable and fast,,what is the power goal or do you even have one??,,if your looking for sutin easy and just want a engine real quick, then go with the b17 as a vtec head will work great with ease,,,,a lsvtec of coarse with the same cr will ALWAYS make more power...but you will have to do work to the block so it can handle the revs...theres no replacment for boost:)
