ls smoking
  • ls smoking
    i got a 1991 ls motor it runs strong as hell but the other day it started smoking bad it is like whitish gray and i am loosing oil it only smokeswhen i stop at a light or am at a low rpm. i did a compresion test it cam back good great numbers i put a can of sea foam in it it stopped the smoking for 2 days now its back the motor only has like 2000 miles on it any seggestions
    RUN YOUR CAR NOT YOUR MOUTH
    pcv system or piston rings,valve seals..has to be one of these or all of them..lol
    Originally posted by knuckk
      im gunna say valve seals on this one.
      your better off just replacing the valve seals and head gasket.
      make sure you dont have coolant and oil mixing.
      if you have good compression id assume piston rings last.
        check your pcv valve/system. Thats my guess.
          ok guys thanks im going to start small than go big i guess lol i just want it fixed so i can sell it
            Egr or pcv
              i just want to say thanks for the help guys the car is all fixed it was the pcv valve now the car is strait no smoke and running great thanks again
                glad to hear its fixed....if u wannna run it from a dig let me kno...
