obd help on ls swap
  • obd help on ls swap
    i just picked up a b18b motor the other day and the block is definately a b18b block but how do identify the head to find out what obd it is.
    when i do the swap i want to make sure i can pass emissions and all that so this is why im asking. i also gotta make sure i stay obd2 and get all the right parts im gonna need.
    the cars a 96 dx.
    what car did the dude u got it from tell u it cam out of
    D and G auto member #5
      look at dizzy it should have one plug if its obd2 two plugs if its obd1
      B SERIES INC....
        x2
          theres no dizzy. kid said it was from a 97
            b18a 90-95 96 and up came b18b as in obd2 96 and up is obd2
            then u got a and b and thats something else!yada yda yda
              thats what i mean, how do i tell what head i have? it has an older valve cover, not the newer smooth ones
                Who cares for emissions purposes you are fine. Run a obd2 dizzy, obd2 injectors. and make sure you have a obd IM with all the sensors. Or you can use a obd1 and run the sensors off of it. Either way wether the head is obd0,1,2,3,4,5,6,7a,b,c. your good for emissions,
                  oook. thanks bro. would be nice to know what i got too.
                    ywa i kno on the front of the heads you can read, not sure about an ls tho. Im assuming it's the same but not positive.
                      not to be an ass bro but 90-93 are b18a1 94 and up are all b18b1 obviously 94-95 are obd1 same valve cover as b18a1 and 96-97 are obd2a 98-01 obd2b which comes with tha new valve cover
                      B SERIES INC....
                        oooh ok, gotcha. thanks for clearing that up bro.
                          np man just tyrin to spread tha knowledge
                          B SERIES INC....
                            no sir! Look it up or post a better answer!
                              uh im not gonna argue wit u bro i kno my shyt go any where here just go here http://en.wikipedia.org/wiki/Honda_B_engine#B18A1 ok get ur facts before u come trying to prove someone wrong!
                              B SERIES INC....
