???help
  • ???help
    im doing a swap and the harness i had, i heard the fuel pump feeding...now i switched the harness and now i dont hear the fuel pump feed anymore...so my question is should i change the other harness back or should i leave it the way it is and see what happens?
    wat swap in wat chassis?
    B SERIES INC....
      ls in a ef
        was the ef origanal dual point injection or is it a si?
        B SERIES INC....
            ok so da harness u are usin now is tha obd0 ls one right?if i were u just use tha stock harness and wire th other 2 intectors in straight to the ecu
            B SERIES INC....
              the harness thats's on now is the stock 1 but i dont hear the fuel pump feeding...and when i used the other wire harness i heard it...but y to the ecu?
                cuz tha ecu is wat controls the fuel just go here http://ef-honda.com/ben/EFwiring.php it tells u wat to do
                B SERIES INC....
                  goodlooks
                    no prob
                    B SERIES INC....
