so my oil pressure dropped the other day there was metal in the motor but i wasn't sure if it was from the motor the pan was on previously .. i mean i tried to douche it out the best i could.. changed oil pump today nd it started fine no knocks or ne thing .. but i put a used pump on due to being poor was said supposed to b good ... now went around the block after it warmed up i tried to pop vtec it worked like 5 or 6 times within a little then turned back onto my road went to pop one more time it didn't work nd i watch the gauge start to drop ... i'm gettin may b 2 or 3 psi on idle wuts goin on ??? ne one have a cheap new oil pump 4 b series
no oil pressure
well tomorrow i'ma drain the oil w/ my handy new magnetic drain plug nd c if theres ne new metal in there if not i'ma vote no bearing issues jus old metal in the pan .... may b the pump isn't good cuz i primed it for a while b4 start up
Originally posted by CTgoldhatch View Postthe main berings could be shot wont knock just yet but will make oil presser low and vtec wont work with low oil presser. time for a new motortheres no replacment for boost:)
