whats the advantage of running n ls wit a b20 head?
  • whats the advantage of running n ls wit a b20 head?
    my boy has a b20 head he ported and polished and hes selling it for cheap is there any advantages of throwing the b20 head on my ls? n can i use my same headers? and if i did do it what head gasket would i have to use?
    2.0>1.8 ..headers should fit
    *S14 Kouki *
      i beleive if u throw on the head u woould get a bit more airflow nothing major dow not a big deffirane from ls 2 b20
        whatd bout head gasket?
          Ls haed gasket......
          TURBO 2001 IS300
            but does it raise the compression at all?
              bumpp
                it will lower the compressin it has a bigger chamber on it so it will drop it not by much tho.
                the flow is just about the same as a ls you said your boys was P&P so it will flow a lil better.
                as for hedder and intake it is the same some b20 came with different style intakes for better toqure but not may of them
                you want to find the b20 head that is stamped P8R inside the cam are it is a better flowing a higher compression motor the best b20 head and very hard to find.
                  ^ beat me to it good shyt bro
                  TURBO 2001 IS300
                    nice good looks guys
                      Originally posted by ctgoldhatch View Post
                      you want to find the b20 head that is stamped p8r inside the cam are it is a better flowing a higher compression motor the best b20 head and very hard to find.
                      i had 1 sold it for 50 bucks...just go vtec
                      WILSON BUILT
                        Agreed on going v power if u want to make some extra power
                        S3-R
                        Stage3-Racing
                          yea but i was think of spraying my ls cuz itd be cheaper i think
                            did you try to race me on the brige the other day in a white eg 4 door?
                              There is no difference what so ever, a b20 head is just an LS head. Some come with a P8R head, but its extremely rare. P8R head has 84mm chambers.
