ls burnin oil
  • ls burnin oil
    i changed the valve cover gasket and spark plug gaskets and still burnin oil and white smoke
    g/l
      i think it might be your headgasket but dont quote me
      R.I.P Nick aka NHSwaps
        ight gud lookin bro
          valve seals
            white smoke is head gasket. change your head gasket
              Headgasket for whitee smoke
                just get used to burning oil... u drive a honda hahaha jk good luck wit it
                  how does the smoke smell....sweet = HG
                  Is it overheathing?
                  check oil level ...too much oil = white smoke
                    my ls burns oil cuz of da rings,,,if its ur headgasket then ull either see it in ur oil and water mixing or it should over heat
                      Is it overheathing?
                      before you do all this work which may be needed do a simple compression test, that will give an idea of the conditions over all of your engine...
                        ^^ first dude saying something sane..
                          do a compression and a leakdown test..that will tell u whats going on and where
