my car is normal wen its cold n than afta im driving for bout a half hour... it starts to idle wen i stop... it onlly does it sometimes tho... sometimes its fine... i closed the thing under the TB wher the coolant goes into... i had 2 holes in the coolant container next to the radiator that mite have been letting in air to the system... i just closed the holes... n now its a lil better but its still doing the same thing and i cant race lik dat cus at take-off its idling... lemme kno yall input thanx
idle problem
im having the same issue its either an air bound cooling system which is time consuming to bleed or a vacuum leak... what im doing now is taking radiator cap off-topping off fluid (engine off first) some air will bleed out then run engine with cap off top off until stops bubbling!
For vacuum leak spray carb clean on lines (with engine runing) if idle raises then that line is leaking and needs to b replaced!
Originally posted by greasemonkey531 View Postim having the same issue its either an air bound cooling system which is time consuming to bleed or a vacuum leak... what im doing now is taking radiator cap off-topping off fluid (engine off first) some air will bleed out then run engine with cap off top off until stops bubbling!
