ls/vtec build help!!!!!
  • #31
    Originally posted by realjdm View Post
    I have a question i have a jdm b18c im going to put ctr pistons asl bearing should i just go ahead and change the rods or just use the stock ones.
    well your in their might as well change em. can always go to itr rods i believe they are a little beefier than gsr's.
    • #32
      i say since you already there go ahead and get some forged rods to have that extra durability
      S3-R
      Stage3-Racing
      • #33
        Thanks
        97 Boosted Hatch my toy
        • #34
          $100 or trade for jdm gsr pistons n $50.
          Dats not bad at all r dey used?
          • #35
            brand new
            • #36
              brand new. i put a link to his thread.
              • #37
                OEM honda internals are proven to handle 200hp+, you don't even need injectors.. just bumping your fuel pressure will get you there. invest your money where it counts.
                get the CTRs, get some arp rod bolts, Type R intake manifold, send you throttle body to get bored, its going to cost you about $130 and will come back at 64mm plenty for a 1.8, and get some rmf or hytech replica headers and some skunk2 or bcIII cams. you won't spend more than $1500 if your look around
                • #38
                  Yea I saw it thanks 4 ur help guys hopefully it comes 2gether gd
                  • #39
                    Sounds gd a lot of money but its worth da build
                    • #40
                      my next motor sleeved 81mm gsr block with ls crank and rods.
                      ls/v disguised as a gsr.
                      • #41
                        if i can find a gsr block i would do it on the gsr cuz the girdle and put an ls crank but since those are expensive 87mm sleeve b20/vtec with aftermarket girdle kit
                        cant wait 15+:1 compression
                        S3-R
                        Stage3-Racing
                        • #42
                          U can get da block cheap at da junkyard
                          • #43
                            Bump I'm building an ls v to .. Good to kno info
                            *S14 Kouki *
                            • #44
                              Yea I think it would be a easy gd build
                              • #45
                                i just did a ls/v tonight. not hard at all.
