Car is Dyin at 6500 rpm.. HEELLLPPP
  • Car is Dyin at 6500 rpm.. HEELLLPPP
    When i drive the car normally it drives fine onces i reached 6500 rpms it like shuts off or dies n starts n dies again... vtec engages fine .. evrything.. i need help fro the real tech guys.. i have a stock fuel pump and i have a type-r...wts wrong.where my techs at???
    I noticed that my rpm gage was like floating, and it misfires, it doesnt die
    bummmpp i need help....bumppppp
      weird. no cel? smoke at all? Possibly bad dizzy?
        nah no smoke no nuffin......evryone tells me its my dizzy.....im lookin for a second opinion
          if everyone tell you dizzy go with what everyone suggest. I personally think its the ecu or dizzy. one of the two is throwing up
            yup. check timing as well.
              first off, what is your setup?
              (860) and beyond
              #DavesTuning 8608050968
                I had that problem wit my integra then a week later I heard rod knock and ended up with 2 spun bearings
                95 del sol
                92 4door
                  well my motor is fine, my oil is fine..evrything looks fine... i messed with my dizzy n it worked for a lil bit...den went bak to the problem.... i also noticed that my rpm gage was like floating,, n it does die, it misfires from wat i learned
                    xplain bout tha car mor.. erething u got on tha car engine ecu car year...etc
                      probably a sensor
                        replaxe the distributor and problem will be solved
