i gotta clean tha inside b4 i put tha head on.. whats tha best way to do it with out messing nething up??? i alredy put fresh valve seals on... lemme kno wat yall be doin...
best way to clean b18b head
Is all the same sh*t the liquid will get all over the head whether through the port or where the camshaft goes.... OK this PLAN A: go to your local machine shop have them hot tank it is 50 bucks at most places.
PLAN B: Do it yourself get a couple of "AutoZone brand" break cleaner cans, don’t! get gunck or advance auto is not the same and wont evaporate as fast, anyways spray the head where the big shit is first then work your way to the et and ex ports til everything is nice and clean. Now the trick to break cleaner it oxidizes aluminum u don’t want that to happen so as soon as your done whether the head is going on in 2hrs or 6 months get a spray bottle of any kind put 10w30 oil and spray it lightly all around on the INSIDE OF HEAD as a lobe. Do not spray around where valve cover gasket would go or where head gasket goes or directly in ports. This will protect the break cleaner from eating into it that’s about it... Note it won’t mess up the valve seals just lobe them good after the break cleanerLast edited by LILRED_TURBO; 08-30-2009, 01:42 PM.
so clean it wit brake cleaner from autozone.. n than just spray it wil oil... to keep tha brake cleaner from eating away at tha sealss... do you have to dry it off first??? n than tha oil or just spray tha oil on afta tha brake cleaner?
