i put an obd 1 jdm b18c in my 95 eg coupe, the car fired right up but hits a soft rev limit around 3200 rpms and bogs real hard if i floor the gas, the mechanic that did the swap says the usdm p72 ecu is bad, I'm looking for some input, also could i put my stock p28 ecu in the car just to see if it is in fact the p72? thanks in advance
gsr swap problem
it will ru non a p28 but not to good it could be a fulty ecu but also could be a wire unpluged some place look over all your plugs and grounds and try to look for a usdm ecu have you p28 chipped if you cant find one call dave the tunner he has a add on here and will help you out.RIP Nick
you cant use a scanner to get codes on a 95 eg you cross the 2 wire in the 2 wire plug on the passenger side that hang down near the glove box and it will flash the code have another question is this a authentic unmolested jdm gsr if so a usdm ecu will pop a code for vtec pressure switch cause the jdm motors didnt use them!!!!!ThE GoOd DiE YoUnG!!!!!
