B16a not starting
  • B16a not starting
    Need some help guys. I recently swaped a b16a into my 91 da and at first it started for about 5 sec and then died out. Now its not starting at all bu still cranking. Now the car is converted to obd1 and distributor and ecu is known to be working because it came off my friends B16. Recently did the wire tuck and swap the only thing that I can thing of is buying a new engine harness. This is not the one that I had on my B18 before I started doing the wire tuck. I replaced the harness because my dog had chewed it up and I picked one up from a member off here. Im getting spark and fuel all my grounds I redid with new wires. If anyone has any idea please lmk. Ive been trying to get this running for about 2 weeks or more and am running out of ideas. Im located in BPT so if anyone has anytime to come by and giv me a hand or wants to look at it lmk. Thanxx
    timing good? could possibly be dizzy. my friends car ran fine one day next day was getting spark but wouldn't start. I put a new dizzy and fired right up.
      A i did the timing once then my boy came over and did the timing then my unclr came over and did the timing with me. So 3x and still nothing. Dizzy i kno is good because it started my boys integra.
        You have the firing order right? 1-3-4-2
          got enough gas in it ? if its jacked up u mite not b pickin it up
            http://i252.photobucket.com/albums/h...iringorder.jpg
            Gotta check that because Ive had a few people redo my distributor firing order thinking it was always wrong. I dont think ive had it in that order yet done.
            It is on jack stands and I was told that but im getting good fuel pressure. Anyways im gonna take it off the stands today and see what happens.
            Thanxx fellas
              just sayin. same shit happened to my boys car. it ws gett spark. wouldnt start i put a ned dizzy and it was fine.
                yo wats ure numba??? ill com threw and chek it out mine is 203 650 6095 joey... call me asap i aint got shit to do n ill com look at it im a nasty ass mechanic n i did a b16a swap on ma old car b4 i sold it... soo i kno how dat engine works soo just hit me up
                  Hey sorry I didnt call man was busy all day. Il hit you up tommorow. Anyways guys heres what it sounds like hopefully someone knows. Getting two codes which are 20 - Electronic load detected and code 6 - which I think is ECT (temp sensor) Heres a link tho of how it sounds.....
                  This isnt my car but I found this video on this forum for 90-93 integras and this guy was having the same problem im havin.
                    It sound stupid but u did a wire tuck so u maybe have a broken wire somewhere check fuses and main realy trust me check fuses
                    "This year pockets will be empty, slicks will be on, and hearts will be broken"
                      Yea i have and there all ok.
                        kinda sounds like possibly the wrong firing order. If you were closer i'd check it out.
                          Firing order im almost positive is on. If im not mistaken its
                          3 4
                          1 2 on the distributor and 4 3 2 1 on the motor. Right?
                            yup. and timing is on. Sounds almost like when I put my b20 cams in my ls n it wouldn't start cuz it needed a valve adjustment.
                              are you sure you have fuel? the car startin for a few seconds an shuttin off sounds like you ran outta gas....the car shouldnt start at all if the firing order is wrong, etc. pull your fuel rail off and make sure the injectors are sprayin
