Hey, i got an extra VAFC chillin at my house and i was wondering if i should put it in or not. Ive been hesitant to install it because ive heard that they advance the timing by 5 degrees just by having it hooked up. This sounds completely retarded because such an advance would cook a honda engine over time. I need to know if the VAFC will actually advance the timing or not just by hooking it up. (for reference i have a jdm gsr and a VAFC1)
How bout them VAFCs?
Tags: None
Originally posted by POS civic View PostHey, i got an extra VAFC chillin at my house and i was wondering if i should put it in or not. Ive been hesitant to install it because ive heard that they advance the timing by 5 degrees just by having it hooked up. This sounds completely retarded because such an advance would cook a honda engine over time. I need to know if the VAFC will actually advance the timing or not just by hooking it up. (for reference i have a jdm gsr and a VAFC1)(860) and beyond
#DavesTuning 8608050968
Originally posted by daveedd357 View Postit will not modify timing until you make changes to your fuel table. Best option is to find someone to tune your engine properly or keep the stock computer. no generic chips.R.I.P Nick aka NHSwaps
Originally posted by daveedd357 View Postit will not modify timing until you make changes to your fuel table. Best option is to find someone to tune your engine properly or keep the stock computer. no generic chips.Originally posted by knuckk@jdmdikk only dude i would take advice from.
Originally posted by YatesTunes View PostThose things are junk anyway. They don't modify the fuel table at all. They alter the MAP sensor return voltage to trick the ECU into adding more fuel. They are a waste of time and money, they just look pretty.
My question is: ....
edited for no conflictLast edited by daveedd357; 07-16-2009, 09:22 PM.(860) and beyond
