Msd removal off LS
  • Msd removal off LS
    ok so when i got my car the guy who had it before me was a ************in idiot and wired the msd all sorts of retarded all into the distributor and wat not and i don't need it so i was just goin to take it out but when i took the main plug "that connects to the coil" off the distributor and took everything out the car wont start it turns over but it's like it just dosn't have any spark somone tell me wat this is and how to fix wat parts i might need to replace
    umm, you really should have asked this question before you took it all apart, but the "wires that go into the distributor" are for the coil, since you had an msd with external coil, there is NO COIL IN YOUR DIZZY or its disconnected.youre gonna have to open up the dizzy and see if the coil is in there or not. if the coil is not there, you have to buy one. you should have left the msd in the car until you had the parts you needed to keep the car running. if you dont have a stock coil, put the msd back in or your car isnt going anywhere.
      thanks for the advice took me a while but i rewired eveything the right way with no msd so it will be up for sale soon 6AL with 8400 pill and coil
        how much? I have a coil to replace the one you are missing if needed,.
          glad i could help
